Assuming the ruckus ECU variants are different to each other, does the ECU need to stick with the wiring loom or the engine? Or both? Or can you mix and match whatever?
Pretty sure you can swap them out… correct me if I am wrong but I have, many times, swapped a new one for another… maybe I just got lucky?? I never checked the part number or anything
