Zoomer front wheel with 120/70R10 conti twist tyre
Zoomer front triple tree
Zoomer front brake
Adelin low down front shocks
TRS front brake shock adaptor
Sinnis Zen 125 front fender with custom mounting bracket
1” Smoked front LED button indicators
Custom CNC handlebar stem riser
low down CNC clip on handlebars with cafe style grips
Koso digital speedo
Custom speedo mount bracket
Zoomer throttle cable
Zoomer front brake cable
Zoomer rear brake cable
Met brake biaser removed
Zoomer rear CVT arm
Tokyoparts rear hard tail arm
FLP cvt kickstand
Doppler airbox
Harley Sportster rear LED cluster. Plastics infilled and cut to suit.
10x5 DWT wheel with 130/90R10 Conti twist tyre.
Custom rear number plate mount
Need to get the stock cluster plastics back on
Paint!
I believe this is one of only two in the UK. There were two others (unregistered Scoopys from South Africa?) but they got sold in to Europe.
Progress on this will probably be slow. I have most of the parts (spares from my Zoomer) but I don’t have much time.
The build log below is a bit all over the place, but it’s just the order I did things - jumping from one thing to another whilst I waited for parts etc.
When I bought my Met, the previous owner had crashed the front. The front fender was broken, the front wheel was buckled, the handlebars were bent and the tree was possibly bent. I just hoped that the frame was straight and not cracked.
I passed my mot the other day, and they said it barely passed. Because of the steering head bearings and the buckled wheel. They said it likely won’t pass next year. So I thought now Is the time to fix it.
I ordered new Zoomer steering head bearings but I have been slowly gathering parts for this anyway…. My plan is to use as many Zoomer parts as I can so that they are readily available in the UK.
For anyone who finds it useful, this was my starting list of parts. Will probably need more…
*Ruckus triple tree with bolt and clamp washer
*Tree riser
*Handle bars with bolt and clamp washer
*Ruckus front wheel
*Ruckus front brake
*Ruckus rear brake cable
*Low down front shocks with brake adaptor
*Speedo
*Bracket for original Met speedo housing
*New steering bearings
*Fender of some sort (temp) til widened
*Ruckus rear cvt case
*Ruckus length belt
*10x5 mini fatty
*Zoomania hard tail arm
*Ruckus length airbox hose
*Rear number plate mount
*New rear tail light
*Front button indicators
*Rear button indicators
So I started to replace the front…
Good news is the that frame isn’t bent or cracked. The wheel and bars etc are shot though.
First thing I have learnt. A met is like a child that takes all its clothes off to pee!!! No matter what you do, you have to remove all the plastics!
Then there is the combined brake cables, so f’ it. I’m in the whole way. Zoomer rear end is happening at the same time.
So up front I have installed a Zoomer wheel, hub, low down adelin shocks and the wider Zoomer triple tree with new steering bearings. I’ve cnc’d a riser out of 6081 and have gone for some aftermarket handlebars with the original controls.
I can’t get a met fender over here so have been buying old second hand ones to see what fits. I think a Sinnis zen 125 is the winner (the red one). If I was keeping the Met tree the Sinnis flair 50 would have been the best.
I have now cut the top of the fender neatly and made some brackets - just waiting for them to get laser cut. It fits the wheel ok, but I won’t know if it clashes with the front frame plastics till it’s all together…
The dual brake thing has been removed, So new zoomer front and rear brake cable installed to take its place.
I have a Koso speedo gauge to go on, just waiting for the bracket to get laser cut again.
So on to the rear. Have swapped to a Zoomer rear cvt arm. Douglas 10x5.
I cut the bushing off the left hand side of the CVT case, and packed the engine mount on the other side. So the engine is moved over circa 10mm to the left.
These 3 photos aren’t mine (courtesy of Derek Marciniok), but I didn’t take photos, and it’s a common question.
To center the ruckus wheel, you have to move the engine over to the left. To do this, you need to cut off the metal spacer sleeve from the LHS of the ruckus cvt case here:
Don’t want to get after market controls so either going to get different bars, a longer riser, or something else…
I was also hoping to use the stock airbox due to uk weather, so swapped to a ruckus intake hose and fitted the box. It won’t fit under the rear plastics either way. So air filter it is. Going to use a Doppler air box to keep the rain out.
It fit really well with where I cut the inner fender. I’m just wondering if it’s too low. I need to drop the rear hard tail, and the light will probably be the limiting factor if I leave it where it is.
It’s the same design as my Zoomer but seems higher up. I think that’s just because the plate isn’t on yet and the bike is on a centre stand instead of a side stand.
Mock up of front fender bracket on fender. I used plastic JB weld to hold the nuts in place to make it easier to fit when on the bike:
I put the front fender on. It was a b1tch to get on (no access for doing up bolts). And now that it’s on I’m not sure if I like it. Will do for now until I can get one from the states somehow.
Also I swapped the Met throttle cable for a Zoomer throttle cable. The Met one is approx 70 to 71” sheath length. The Zoomer one is 75-76”. So that extra few inches meant that I can rotate the cable forwards and it clears the plastics:
Currently wiring up the rear cluster, front indicators and Koso speedo.
There wasn’t really anywhere suitable to mount the Koso sensor, so I cut up the standard bracket and drilled a counter sunk hole so I could bolt it to the original speedo hole mount. This is also where I previously had the trail tech sensor, so don’t have to move the magnet bolted to the wheel.
Thanks Gbisk. I used to love reading other peoples build threads and also the how-tos on the original total ruckus forum. I fear it’s a dying format with everyone on YouTube or whatnot nowadays, but I prefer this format.
This build is slow going, but am also enjoying being able to look back at the progress I’ve made so far.
Have cranked down the tokyoparts hard tail as far as it can go. Well, as far as it will go and still be able to get the bolt through he top. The geometry doesn’t quite work to make it as short as the thread allows.
The stand is now vertical, which means that you only have to nudge it and it falls off. So I was going to grind the stand mount to allow it to sit at the right angle, but luckily someone in the UK just put a cvt stand up for sale. At full price, but it will make my life easier.
As ever with the Met, one thing leads to another, so removing the original kickstand means removing the locking cable that’s goes with it.
Lowering the rear, I also raised the rear light, so need to cut the rear plastics to suit again. Have ordered a plastic welder to make good after, going to try and get a piece below the light as I think this looks much better if you can.
Still got some fettling to do, but main things left to resolve are:
I don’t like the front fender. But it’s staying for the moment.
need to find a Doppler airbox due to the UK weather. They seem to be like hens teeth at mo.
need to decide if I’m going to have the grab bar on the rear or not.
need to work out why the hi beam warning light works when the headlight isn’t plugged in, but is constantly on when it’s plugged in.
design and cut a new speedo bracket that holds the original plastic speedo surround.
work out what colour I’m gonna make it and if it will be paint or wrap. Although i miss riding it, so will wait for a bit before i take it apart to paint.
After that, I think im probably done. I think I prefer the Met to my Zoomer! Although the Zoomer gets way more attention.
Making a bracket (114mm between bolts, and 8mm offset - so 16mm wide). This will run between the cvt cover bolts and then the airbox will bolt to this.
Have had to cut a little bit off the airbox mounting tab (plastic tab on the bottom of it where you drill through) to move it forward as much as I can as well.
So it’s up and running. Took it for a test ride and the rear brake cable is rubbing. Don’t know why the Met doesn’t like to play, but same wheel, cvt arm and cable as was on my Zoomer and it wasn’t an issue. But anyway. Made myself a p clip out of an old metal rule. to hold the cable away from the wheel.
